Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Report Generation Toolkit 2019 64 y microsoft office 64
hola amigos.
tengo una duda antes de instalar labview 2019 64bits, quiero saber si el Report Generation Toolkit 64 es compatible con mi microsoft office 2016 64bits.
he realizado proyectos en 32 bits. ahora requiero hacerlo en 64.
gracias.
0 kudos
Mensaje 1 de 3
2.663 Vistas
Translation:
Hi friends,
I have a doubt before installing labview 2019 64-bit, I want to know if the Report generation toolkit (64-bit) is compatible with my 2016 Microsoft Office (64-bit).
I've created projects in 32 bits, and now I need to do it in 64.
Thanks.
Source: My parents are from argentina, I'm fluent in spanish
0 kudos
Mensaje 2 de 3
2.628 Vistas
I wonder if you ever found an answer. Just leaving this hear in case some one else stumbles unto it.
The LabVIEW 2019 Report Generation Toolkit for Microsoft Office Readme can be found here. According to it, the 64-bit version is compatible witgh Microsoft Office 2016/2013/2010/2007/2003 (32-bit) (Microsoft Office 2013 is also included in Microsoft Office 365), so you can use Microsoft Office 2016, but it has to be the 32-bit version.
Camilo V.
0 kudos
Mensaje 3 de 3
2.465 Vistas
