Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
dataproof scanner problem using gpib
      I'm using GPIB USB HS and I've got some problems detecting a dataproof scanner 320A: It detects multiple instruments and is unable to communicate with the scanner.
      Have you noticed this problem before?
      Thank you,
         Emilio Ibáñez
0 kudos
Mensaje 1 de 3
3.519 Vistas
This look likes an installation problem. I recommend you to follow these troubleshooters to try to find where the problem is:
http://digital.ni.com/public.nsf/allkb/E8CAFBC41A7B9BF086256D3C00650011?OpenDocument
http://www.ni.com/support/trouble_gpib.htm
http://www.ni.com/support/troubleshooting.htm
0 kudos
Mensaje 2 de 3
3.471 Vistas
   The problem is nothing like this, it works fine with other instruments, it seems it only have problems with the dataproof scanners. Any other Idea?
   Thanks for your time.
         Emilio Ibáñez
0 kudos
Mensaje 3 de 3
3.456 Vistas
