Discussão sobre Produtos NI
cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
IDE LabVIEW 2013 extremly slow with Actor Framework when using 200+ classes
AF creates a lot of classes, one of every thing I want to message. Mid-sized projects get extremly slow due high quantity of classes, and normal operations that would take seconds sometimes take minutes. Compiled code runs smooth.
NI should not recommend use of AF if IDE cannot handle too much classes.
I'm rewrithing using SMO JKI  from scratch a almost finished project that was built in AF since it got unmanagable due every operation taking 10 minutes.
Mensagem 1 de 3
16.223Exibições
Unfortunately does not exist a solution for LabVIEW 2013.
We contacted the member 3esmit to search a solution. At this moment the unique solution is to update LabVIEW to version 2015 or newer.
Daniel Fernandes
Applications Engineer - NI Brazil.
Mensagem 3 de 3
11.261Exibições
