Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
AD7622
Hello everybody,
I work on a project where we're using a ADC, the AD7622 which is a 16bits, 2 MSPS converter.
We have a problem with it, it doesn't work.. we chose this way of working and interface :
- we work in parallel mode : ser/par = 0 to read the 16 bits directly
- Byteswap = 0 to have the LSB on D[0;7] and the MSB on D[8;15]
- WARP = /NORMAL = 1
- OB/2C = 1 to make the output coding straight binary
- PDREF = PDBUF = 0 to choose the internal reference whis is 2.048V
So we are in parallel interface and we chose to work with /CS = 0 and /RD = 0 to be in Master Parallel Interface then we only use /CNVST to initiate a conversion.
Moreover I thought that it was the signal CNVST that I didn't generate as well but that's false because we use differents ADCs like the AD7656 and it works! We need the AD7622 because of his accuracy.
When I make the signal's acquisition, I can see that the bits 5 , 6 , 7 , 8 , 9 are oscillating which is not normal because I convert an analog signal coming from pile (with V=1.3V < Vref). Normally it should be the LSBs bits which can oscillate but not the bits 6 7 8 9 ....
I respect the different timings to be sure to read when the data is durable. When I initiate a conversion with the CONVST bit I can see the Busy bit going High so the ADC works but the final result is disturbing...
Furthermore, every decoupling capacitor and differents resistance as shown at p.16 have been respected. DC ground to a DC ground and analog ground to an analog ground.
This is a differencial inputs ADC, the inputs must be symetric. That's ok because we put a ground (0V) onto the 2 inputs In+ and In- so it should work.
I don't understand why the ADC doesn't work, maybe I didn't understand a part of the Datasheet especially interface and modes..
If anybody can helps me it would be nice.
0 Compliments
Message 1 sur 5
3 819 Visites
Maybe your ADC suffers from ESD...Did you try changing it with another one ?
I don't understand what it has to do with National Instruments products ?
You should be more explicit.
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
0 Compliments
Message 2 sur 5
3 813 Visites
Yes we try to change it but it has the same behaviour. I put this post into NI product support because I'm new and I thought that a problem with  an Ni product should be here. Where Should I post it?
Did you find a mistake ? the mode the interface?
Moreover, is there a number to contact by phone a NI support engineer ?
0 Compliments
Message 3 sur 5
3 808 Visites
Hmm...
AD7622 is sold by Analog Devices right ? But what kind of NI products are you using with it ? FlexRIO ? CompactRIO ? FPGA R series boards ?
Did you use an API to interface NI products and the ADC ? Or did you use LabVIEW and grapical programming only ?
You can contact an engineer at this number : 01 57 66 24 24
Da Helmut
0 Compliments
Message 4 sur 5
3 797 Visites
dear labview123,
May I know if you could solve the problem pertaining to the bit toggling in MS Bits of the AD7622. Actually I too am facing a similar problem pertaining to AD7656. Here the Direction bit is responsing properly but rest all bits are toggling indiscriminately. The effective variation in outputs is in the range of +/- 1Volt level.
It will be helpful if you can respond with the solution you incorporated in the AD7622 case that could sort the problem out.
Thanks in advance
Regards
0 Compliments
Message 5 sur 5
3 608 Visites
