Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Cannot create an installer with NI-Measurement studio installed.
After installing Measurement Studio on my development machine, it was no more possible to create an installer with LabVIEW.
I had to remove all the National Instruments software (LabVIEW, Measurement Studio, ...) and to reinstall LabVIEW. Now it is working but I have to use another machine to build C# applications with Measurement Studio.
Does a trick exist ?
0 Compliments
Message 1 sur 2
3 551 Visites
Hi pacome,
you are on the French community of NI Forum, so you can post in french.
I think the problem is either due to a bad install, or it's a problem of different version installed when installing Measurement Studio.
You could find an explanation of this issue in the following link :
http://digital.ni.com/public.nsf/allkb/C3666BA408F81E59862570D20056E692?OpenDocument
and an possible workaround in this link :
http://digital.ni.com/public.nsf/websearch/5C55288F366FC5CA862570F500680F7C?OpenDocument
Hope this helps.
Olivier L. | Certified LabVIEW Developer
0 Compliments
Message 2 sur 2
3 536 Visites
