Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Should I modify the camera file to change the greyscale resolution from 8 to 12 bits of my Photonfocus camera?
I have some difficulties to use my Photonfocus camera with 12 bits greyscale resolution.
I have a Photonfocus camera MV-D1024E-160-CL-12, a NI PCIe-1429 frame grabber, PFRemote 2.0 and Measurement & Automation Explorer 4.2.1.3001.
If I work with 8 bits greyscale resolution (PFRemote -> Data Output: Resolution : 8 bit) and look at the image with MAX (Système -> Périphériques et interfaces -> NI-IMAQ Devices -> img0: NI PCIe-1429 -> Channel 0: PhotonFocus MV-D1024-160 (file in attachment), everything is working.
Now I'd like to work with 12 bits and I don't know exactly what I have to change? I've tried to change only the resolution in PFRemote (PFRemote -> Data Output: Resolution : 12 bit) but then the image in MAX remains a 8 bit resolution. Then I've tried also to modify the camera file (file in attachment). I've put the "BitDepth" and the "BitsPerComponent" at 12 instead of 8 and the "BinaryThreshold" to (0,4095). But when trying to grab an image in MAX, an error occured: "Error 0xBFF600FE Le nombre de bits par pixel requis est invalide".
Should I really modify the camera file in order to grab 12 bits images? Or what should I do?
Thank you
Mélanie
0 Compliments
Message 1 sur 1
3 961 Visites
