Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
connected the USRP2930 with my computer
Hello
I encounter a problem with the NI-USRP 2930,my computer (windows 8)can't find the device when i use the cable ethernet
thanks
0 Compliments
Message 1 sur 3
4 038 Visites
Can you give more details. Your USRP is recognized under MAX ? Did you have any error message ? All the leds work fine ?
Best regards.
0 Compliments
Message 2 sur 3
4 013 Visites
Hi
I found the solution , the problem was that the IP configuration
thank you so mush
0 Compliments
Message 3 sur 3
3 983 Visites
