Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
continuous analog acquisition with DAQmxBaseReadAnalogF64 reads only 2 values in buffer
I want to continuously acquire an analog signal, to process it real time.
I therefore use the code given in the example /usr/local/natinst/nidaqmxbase/examples/ai, but change the DAQmxBaseReadAnalogF64
pointsToRead to -1 so that I get all the signal up to the current time :
DAQmxBaseReadAnalogF64(taskHandle,-1,timeout,DAQmx_Val_GroupByScanNumber,data,bufferSize,&pointsRead,NULL));
I tried to increase the buffer size, reduce the frequency, whatever I do, there is always only 2 points acquired in the buffer.
Any idea where the problem comes from ?
Thanks a lot for your help,
Elisabeth
0 Compliments
Message 1 sur 2
3 074 Visites
the forum has been posted twice :
http://forums.ni.com/ni/board/message?board.id=250&message.id=18205
Marc L.
NIF
0 Compliments
Message 2 sur 2
3 047 Visites
