Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
generating STANAG-A signal with VIDEO VIs and 5421 board
I currently have a 5421 function generation board to generate standard PAL and NTSC video signals. It works well, but today, I need to generate a STANAG-A signal, and I would like to use this board to generate the video signal. (from bmp an binary video sequences).
I use NI Video Generation VIs which allow to generate PAL and NTSC and some other preprogrammed video formats. Moreover, many attributes can be set up. STANAG-A is a non standard video format (30 fps, 875 lines : 809 active lines)
I tried to change the attribute list accordinly with the STANAG A video format standard, but It seems that I cannot output the right signal.
Does anyone has an idea?
I do attach a file example to explain what has been done on the subject.
Thanks for help ...
Sébastien DURAND
0 Compliments
Message 1 sur 1
3 716 Visites
