Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
ibconf on linux
 I am trying to port my GPIB software from Solaris to Linux and have problem because there is not still the 'ibconf'
utility under Linux  (rehate ws 4). MyGPIB package is NI4882-beta-2.5.1b1.
I use ibconf mainly to give names to my board or to my devices, and I did not found any other solution to replace the
this utility.    It seems that ibconf configures /etc/gpibrc, but this file is not  an ASCII file, therefore can not be edited
Thefefore if someone as a workaround to ibconf, I 'll appreciate a lot.
Thanks in advance
0 Compliments
Message 1 sur 5
3 809 Visites
I don't find workaround for your problem but you should try another installation on Linux. Is the extension of other files can't be edited ?
Steve M.
Message 2 sur 5
3 788 Visites
Is there a reason for having this version of driver? why not the 488 2.5? The version 2.5 is supported by your distribution.
You will have more informations at this link: http://www.ni.com/linux/gpib.htm
Manuel R
AE dans une autre vie
0 Compliments
Message 3 sur 5
3 767 Visites
Hi Manuel,
Thanks for your answer. In fact I tried already the NI488-2.5.1f0 as well (the official release delivered with LV8.6), but I have
still the same question about 'ibconf' utility missing.
Best regards.
Francis
0 Compliments
Message 4 sur 5
3 732 Visites
To use ibconf to configure your card it requires the user to be Root; so, have you got root privilege on your system ? Have you seen  http://xray1.physics.sunysb.edu/~micros/sm/node76.html  to check if your driver is installed correctly ?
ibconf requires libncurses.so.4.0, and in RedHat Enterprise 4  there is libncurses.so.5 I think, so you should "downgrade" your ncurses package . Try this command :
ln -s /lib/libncurses.so.5 /usr/lib/libncurses.so.4
I hope it helps,
Message Edité par Steve Mohamed le 11-03-2008 09:30 AM
Steve M.
0 Compliments
Message 5 sur 5
3 705 Visites
