Distributed Control & Automation Framework (DCAF)
DCAF 1.2.2 Release Notes
DCAF 1.2.2 has been released and is available for download and installation on the NI Tools Network VIPM repository.
The release includes updates to the following packages:
DCAF Execution Engine Interface
DCAF Modbus Module
DCAF Module Interface
DCAF Project Templates
DCAF Scaling Framework
DCAF Scan Engine Module
DCAF Tag Editor
DCAF Tag Select Module
DCAF TDMS Logging Module
DCAF 1.2.2 contains many bug fixes and some new features for DCAF. For a full list of changes see this page.
One highlight includes a contribution from community member knoxberry which adds additional filtering to the engine tags UI so you can filter tags with no writer channel or no reader channels. This will help you to find loose tags in your application.
Upgrade Instructions
The new version of DCAF is available on the NI Tools Network repository and can be installed from VI Package Manager. Each updated package is fully backwards compatible with its previous version.
Note: The DCAF 1.2.2 Core VI package includes an installer for PuTTY (www.putty.org), a free open-source SSH and telnet client. The Syslog functionality requires additional binaries to be installed on execution targets, and PuTTY is used to deploy those binaries from the Configuration Editor.
~ John Boyd
Message 1 of 1
(3,909 Views)
