Distributed Control & Automation Framework (DCAF)
DCAF Configuration Crash
I'm inheriting a large DCAF labview 2018 project from a previous developer. Whenever I try to load the configuration file to the editor it crashes with the following error message. Can anybody help me to figure out this crash?
Exception: Access violation (0xC0000005) at EIP=0x06397484
Jonathan
(1,985 Views)
I deleted the project, got it again from the repo and it doesn't crash now, but now after loading the file the custom modules say they are unable to load. Any ideas? I am loading the same files from the repo on another computer and the modules do not fail to load:
(1,973 Views)
ok, I figured out my issue. I had to add edit the path to look for the file path that the custom modules are located in.
(1,964 Views)
Make sure you add the custom module paths to the configuration editor under Tools menu.
(1,958 Views)
