Distributed Control & Automation Framework (DCAF)
DCAF Editor Executable - failed to deploy configuration
I have build an executable of the editor. I can edit my configuration without problem on my target computer using only the Run-time engine of LabVIEW.
When I tried to deploy the configuration on my cRIO, I have this error :
Failed to deploy file with error :
ssh_init : Network error : Cannot assign requested address
I've got an error before, this was because Putty was not installed. First I download and Putty x64, I just tried with the 32bits version of Putty after restart my computer I still have this issue (Putty 0.74).
It's working well in source and with executable on my development computer (Putty 0.64 installed by DCAF pcakge installation).
Do I need to set something specific to get it work ?
thanks for your help.
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
(4,462 Views)
Accepted by topic author MaximeR
I found the solution. It was the putty version. i installed 0.64 32 bits and it's working. In this case. it was just needed to add Putty path installation inside windows Path to make it works.
Best regards
Maxime R.
(4,424 Views)
