Distributed Control & Automation Framework (DCAF)
DCAF logging to Citadel
I was wondering if this is theoretically possible to do without the use of the DSC.  Any thoughts?
(3,752 Views)
While you could use the Citadel API to log data to Citadel without going through the usual route of configuring a network published shared variable to log directly to Citadel, that API is only available and installed with the DSC module.
If you need to push data to a database, you could certainly write a module to do so.  This is tricky for us to provide in a generic fashion, since it usually depends on the database schema being used.
Cheers,
Matt Pollock
(3,749 Views)
