Driver Development Kit (DDK)
AO channel select for DMA transfers (6229 Board
I am working on an open source linux driver for m-series boards - specifically the 6229 board.  The continuous analog out using DMA works, but only for channel 0.  In order to select the channel I write entries to the AO mode 1 register and the AO_Output_Control register.  So for and example, I want to use AO channel 2, so I write 0x81 to AO_Output_Control, then  0x2 to AO_Mode_1_Register.
Obviously I'm missing something  - can you spot it?
Thanks!
(9,394 Views)
The register used to control the DMA channel selection is AI_AO_Select.  It has 2 fields AI_DMA_Select and AO_DMA_Select.  The valid values for these fields are:
0: DMA Disabled
1: DMA Channel 0
2: DMA Channel 1
4: DMA Channel 2
8: DMA Channel 3
Hope this helps.  If you continue to have problems could you post a code snipet of the configuration.
Diego.
(9,326 Views)
What about dma channels 4 and 5? I'm sure I've read that the m-series boards are supposed to have 6 dma channels. The mite chip itself reports having 8 channels on m-series boards. Thanks.
(8,968 Views)
Hi fmhess-
The bitfield values for DMA channels 4 and 5 are as follow:
3: DMA Channel 4
5: DMA Channel 5
Hopefully this helps-
Tom W
(8,964 Views)
Thank you for your quick answer! It still doesn't work yet, I believe because I'm not setting the mite to use the proper drq line. The mite documentation I have only accounts for the possibility of up to 4 drq lines, corresponding to mite channels 0 through 3. Are there extra REQS bits on the mite in the m-series? The docs for the mite's device configuration register say (the REQS bits are bits 16 through 18 in the register):
REQS[2:0] - Request Source. This selects the type of DMA request for the process.
000 - Internal Maximum Rate
010 - Disable Process. Programmed I/O to the FIFO
100 - Hardware Request 1, DRQ1 line from the IO bus
101 - Hardware Request 2, DRQ2 line from the IO bus
110 - Hardware Request 3, DRQ3 line from the IO bus
111 - Hardware Request 4, DRQ4 line from the IO bus
(8,960 Views)
Nevermind, I've got it working now. REQS bits 100 works for dma channel 4, and 101 works for channel 5.
(8,922 Views)
