Driver Development Kit (DDK)
About second TIO location for M Series
I'm thinking about using both counter 0 and 1.
According to all samples about gpct, that are included in M Series, tTIO object should be initialized with
passing the timer located address like this:
    bar1 = bus->createAddressSpace(kPCI_BAR1);
    boardM = new tMSeries(bar1);
    board = new tTIO(bar1);
    //TIO chip on MSeries boards is at offset 0x100
    board->setAddressOffset(0x100);
It says TIO offset is at 0x100.
On the other hand, I refer 660x sample for that I understand it would compatible in between.
In the 660x sample (gpct_ex9.cpp), it looks like describing 2 counter-use method like this:
  tAddressSpace  cardSpace,cardSpace2;
  tTIO *tio,*tio2;
  //The first TIO is at BAR1+0x0, the second TIO is at BAR1+0x800
  cardSpace = bus->createAddressSpace(kPCI_BAR1);
  cardSpace2 = bus->createAddressSpace(kPCI_BAR1);
  tio = new tTIO(cardSpace);
  tio2 = new tTIO(cardSpace2);
  tio2->setAddressOffset(0x800);
According to the 660x sample, the second TIO is at offset 0x800.
Is there anyone who can tell me how to use the second TIO for M Series?
Thanks in advance.
Ash.
(7,073 Views)
Hi Ash-
There is no second TIO for M Series- all of the functionality is included in the single TIO-like "package" in the STC-II via the G0 and G1 bitfields and registers sprinkled throughout.  There are only two general-purpose counter/timers (G0 and G1) on the M Series devices.
Hopefully this helps-
Tom W
(7,070 Views)
Hello Tom
Thanks I've got it. That's enough for me to know about this issue.
Thank you.
Ash.
(7,068 Views)
