Driver Development Kit (DDK)
Accessing registers on a PCI board
Here is the situation:
I have a PCI board I use as a platform to train in NT driver development.  The board uses 3 resources:
1. IRQ;
2. Memory     (Mem0 - contains 32-bit control registers )
3. Memory     (Mem1 - contains data registers    )
All the resources are processed smoothly in my StartDevice function (below are debug messages from my AddDevice 😞
MC431PCI - PNP Request (IRP_MN_START_DEVICE)
MC431PCI - Resources:
    type CmResourceTypeMemory start        03FDFFF00 length 100
    type CmResourceTypeMemory start        03FE00000 length 200000
    type CmResourceTypeInterrupt  level 16, vector 16, affinity FFFFFFFF
MC431PCI - Translated Resources:
    type CmResourceTypeInterrupt  level 8, vector 194, affinity 3
MC431PCI - Found control memory block. Physical base address - 3FDFFF00, length - 255
MC431PCI - Found data memory block. Physical base address - 3FE00000, length - 2097152
MC431PCI - Got Interrupt Resource 2
MC431PCI - Mapping control memory  ...
MC431PCI - Control memory virtual base address F7CD9F00
MC431PCI - Mapping data memory  ...
MC431PCI - Data memory virtual base address  A9687000
After that I probe my control registers (which called RUK#) using READ_REGISTER_ULONG():
MC431PCI Reading ruk0: 0h
MC431PCI Reading ruk1: 0h
MC431PCI Reading ruk2: 0h
MC431PCI Reading ruk3: 1h
MC431PCI Reading ruk4: 0h
MC431PCI Reading ruk5: 0h
MC431PCI Reading ruk6: 0h
MC431PCI Reading ruk7: 0h
MC431PCI Reading ruk9: 12000012h
MC431PCI Reading ruk10: 0h
MC431PCI Reading ruk11: 0h
MC431PCI Reading ruk12: 0h
MC431PCI Reading ruk13: 0h
As we can see they are all read ok.
Bit 15 of RUK2 controls onboard LED. So just to make sure everything's ok I set bit 15 high, writing 0x8000 to RUK2 and my LED goes bright red.
MC431PCI Reading ruk2: 0x8000h.
After that I leave my HandleStartDevice routine feeling absolutely confident my board is ready to accept control codes and actually execute them. Device manager shows the board just the way i described it in the inf file and resources pane shows the resources settings correct.
I connect to my device via CreateFile and then use DeviceIoControl to send the control code to turn off the LED (remember it's still on). The code which I believed should be written was:
WRITE_REGISTER_ULONG((PULONG) (pdx->membase0 + p->RUK), p->buffer);, where p is a pointer to my PARAMS structure that arrived with the IRP. It simply contains address and data;
Here is what my DispatchControl says to me:
MC431PCI - DATA TO BE WRITTEN: 0h
MC431PCI - ADDR TO BE WRITTEN TO: 8h
MC431PCI - WRITING 0h TO RUK2 ....
MC431PCI - SEE WHAT'S IN RUK2: FFFFFFFFh
Well as we can guess the LED is still on and I end up being unable to write nor can i read from my device.
So the question is why once I leave HandleStartDevice routine I lose contact with the PCI board.  I can no longer read or write. I even tried to address my register directly avoiding HAL :
first writing into RUK2 still hoping to turn off that LED:
*((PULONG)(pdx->membase0+RUK2)) = 0x00;
and then reading from it
*((PULONG) (pdx->membase0+RUK2)).
The result is still FFFFFFFFh . I of course can turn it off while still in HandleStartDevice.
Any idea where to look? What happens once HandleStartDevice returns?
(7,123 Views)
What chip are you using on this PCI card? Is this an NI chip like the TNT chip?
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(7,104 Views)
