Driver Development Kit (DDK)
Data is unnormal with hw timed acquisition with dma on aiex3,please help me
Hello,I want a continuous mode,I modify from example aiex3:
1) enable continuous
const tBoolean continuous=kFalse ;---------->const tBoolean continuous=kTrue;
2)config dma to ring mode
   status=dma->config(0,tDMAChannel::kNormal,tDMAChannel::kIn,dmaSizeInBytes,tDMAChannel::16bit);
   -------->status=dma->config(0,tDMAChannel::kring,tDMAChannel::kIn,dmaSizeInBytes,tDMAChannel::16bit);
3)get data in a infinite loop
   while(bytesRead<totalNumerOfBytes && (kNoError==status))---------->while(kNoError==status)
I run my program without connecting to any signal source,the data I get is always -0.009239. With the program runing,I connect to a signal source , the data I got is
still the same -0.009239. the output of aiex2 is normal .My board is pxi6259 and OS is QNX.
(6,893 Views)
Does aiex3 report good data without any changes? Have you used DMA with QNX before?
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,864 Views)
Thanks Joe Friedchicken.
No error is reported while running aiex3,but data is always -0.009239.
(6,844 Views)
Do you know if the device has been damaged? If you have access to a Windows PC, please use the MAX test panels to confirm that the 6259 can acquire data correctly.
Joe Friedchicken
[ Linux ] [ macOS ]
(6,835 Views)
