Driver Development Kit (DDK)
IMAQ1409: question on imgPulseCreate function.
In VC++, I used the following functions to generate some pulse.
errChk(imgSessionTriggerDrive(Sid,IMG_EXT_TRIG0,IMG_TRIG_POLAR_ACTIVEH,IMG_TRIG_DRIVE_UNASSERTED));
imgPulseRate(1000,500,&delay,&width,&timebases);
errChk(imgPulseCreat(timebases,delay,width,IMG_IMMEDIATE,IMG_TRIG_POLAR_ACTIVEH,IMG_EXT_TRIG0,IMG_PULSE_POLAR_ACTIVEH,PULSE_MODE_TRAIN,plsID));
But it always give me the error message:
invalide parameter #1.
What is wrong with the first parameter??
Thanks.
(9,960 Views)
I also want to know,
1.whether the imgPulseCreate function generate a TTL signal or not, why I can not display it in the 0-5v range by oscilloscope?
2.PULSE_MODE_TRAIN, why it can not display continuous pulse?
(9,960 Views)
Why I cann't generate continuous pulse by IMAQ1409?
Why the amplitude(value) of the pulse isn't correct?
Pls answer this question!
(9,960 Views)
imgPulseRate(1/1000,1/1000,&delay,&width,&timebases);
I sovle the error message:
But still with the other two problems.
(9,960 Views)
Hello TNI,
This question is probably better posted in the Vision section of the discussion forum. The MH DDK section is meant for questions related to register level programming of data acquisition hardware.
Christian
NI Systems Engineer
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(9,960 Views)
