Driver Development Kit (DDK)
Instrument Driver for Hommel-Tester T2000 (Surface Roughness Profilometer)
I am using a Hommel-Tester T2000 Surface Roughness Profilometer with data output via printer only.
No I would like to implement data output via the RS232 serial port.
Does there exist a software solution providing this quite simple feature?
Thank you.
A.G.
(8,157 Views)
duplicate post
Also. this is not at all the correct board. This is the board for the DDK to write your own driver for NI DAQ boards.
(8,151 Views)
Thank you.
(8,138 Views)
