Driver Development Kit (DDK)
Is there any DDK, RLP or examples programming Relay cards PXI-2567?
I am trying to write a Device Driver for PXI-2568 Relay card. I can not find any Device Driver Kit (DDK) or Register level Programming (RLP) information. I program in Visual studio C++ using VenturCom RTX. I have diver for M and E series ADC cards as well as DIO cards, but can not find any help for the relay cards. Where can I find any examples or other info?
Tony
(8,605 Views)
I am looking for the same thing (how to program the PXI-2567).  I am using Green Hills INTEGRITY operating system on a PowerPC in a cPCI chassis.  WE have used the Driver Development Kit successfully in this environment for the PXI-6704 and PXI-6509.  Maybe there is some kind od Register Memory Mapping ... Thanks, Alvin
(7,888 Views)
Hi Alvin,
One setup is done. all you need to do is write the approperiate value to the IMMEDIATE_MODE_REG_ADDR  0x0DC to open or close a relay.
The Switch RLP manual is attached. Good luck.
Tony
(7,885 Views)
Thanks so much.  We will give it a try,
Alvin
(7,870 Views)
