Driver Development Kit (DDK)
M-Series Buffered Event Counting with DMA -- gating problem
Hi --
I am implementing DMA-based buffered event counting on a PCIe-6259 board.  I use G0_Out as the gate for G1, which counts events on a PFI pin.   So by setting the speed of G0, I get an event count (either cumulative or non-cumulative) on a periodic basis, which is directly DMA'd to my buffer, and synchronized with other i/o operations.
This is working well right now, except for one problem, which is that the I only get data if there is at least one  source edge between gates.  i.e. if there are no edges, nothing gets pumped to the dma buffer.
I am guessing that a stale data error is somehow choking off the DMA transfer from the counter.   Is that possible?
Is there some magic that I need to do to avoid this, because for this application, especially if I am counting cumulatively, I don't care about a missing edge, but I do care if the dma transfers get out of phase with the rest of my timing.
Thanks in advance for any help!
--spg
Here is a snippet of the code that sets up the event counting on G1, partly based on gpctex6.cpp:
const int sDMASelect[] = {1,2,4,8,3,5};
// source:  pfi, or -1 for 20Khz clock
void eventTimerSetup(tMSeries *board, tTIO *tio, int dmaChannel, bool cumulative, int source)
    int sourceSelect = (source==-1) ? 0 : (source+1);
    //MSeries.CTR.Source
    tio->G1_Input_Select.setG1_Source_Select(sourceSelect); // (pfi+1) or 20Khz=0
    tio->G1_Input_Select.setG1_Source_Polarity(0); //rising=0
    tio->G1_Input_Select.setG1_OR_Gate(0);
    tio->G1_Input_Select.flush();
    //MSeries.CTR.Gate
    tio->G1_Input_Select.setG1_Gate_Select(20); //the G_OUT signal from other clock=20
    tio->G1_Input_Select.setG1_Output_Polarity(0); //active high=0
    //MSeries.CTR.IncrementRegisters
    tio->G1_AutoIncrement.writeRegister(0);
    //MSeries.CTR.InitialCountRegisters
    tio->G1_Mode.writeG1_Load_Source_Select(tTIO::tG1_Mode::kG1_Load_Source_SelectLoad_A);
    tio->G1_Load_A.writeRegister(0);
    tio->G1_Command.writeG1_Load(1);
    tio->G1_Load_B.writeRegister(0);
    tio->G1_Command.setG1_Bank_Switch_Enable(tTIO::tG1_Command::kG1_Bank_Switch_EnableBank_X);
    tio->G1_Command.setG1_Bank_Switch_Mode(tTIO::tG1_Command::kG1_Bank_Switch_ModeGate);
    tio->G1_Command.flush();
    //MSeries.CTR.ApplicationRegisters
    tio->G1_Input_Select.setG1_Gate_Select_Load_Source(0);
    tio->G1_Mode.setG1_Reload_Source_Switching(tTIO::tG1_Mode::kG1_Reload_Source_SwitchingAlternate);
    tio->G1_Mode.setG1_Loading_On_Gate(cumulative ? tTIO::tG1_Mode::kG1_Loading_On_GateNo_Reload : tTIO::tG1_Mode::kG1_Loading_On_GateReload_On_Stop_Gate);
    tio->G1_Mode.setG1_Loading_On_TC(tTIO::tG1_Mode::kG1_Loading_On_TCRollover_On_TC);
    tio->G1_Mode.setG1_Gating_Mode (tTIO::tG1_Mode::kG1_Gating_ModeEdge_Gating_Active_High);
    tio->G1_Mode.setG1_Gate_On_Both_Edges (tTIO::tG1_Mode::kG1_Gate_On_Both_EdgesBoth_Edges_Disabled);
    tio->G1_Mode.setG1_Trigger_Mode_For_Edge_Gate(tTIO::tG1_Mode::kG1_Trigger_Mode_For_Edge_GateGate_Does_Not_Stop);
    tio->G1_Mode.setG1_Stop_Mode(tTIO::tG1_Mode::kG1_Stop_ModeStop_On_Gate);
    tio->G1_Mode.setG1_Counting_Once(tTIO::tG1_Mode::kG1_Counting_OnceNo_HW_Disarm);
    tio->G1_Second_Gate.setG1_Second_Gate_Gating_Mode(0);
    tio->G1_Mode.flush();
    tio->G1_Second_Gate.flush();
    //MSeries.CTR.UpDown.Registers
    tio->G1_Command.writeG1_Up_Down(tTIO::tG1_Command::kG1_Up_DownSoftware_Up); //kG1_Up_DownSoftware_Down
    //MSeries.CTR.OutputRegisters
    tio->G1_Mode.writeG1_Output_Mode(tTIO::tG1_Mode::kG1_Output_ModePulse);
    tio->G1_Input_Select.writeG1_Output_Polarity(0);
    //MSeries.CTR.BufferEnable
    board->G1_DMA_Config.writeG1_DMA_Reset(1);
    board->G1_DMA_Config.setG1_DMA_Write(0);
    board->G1_DMA_Config.setG1_DMA_Int_Enable(0);
    board->G1_DMA_Config.setG1_DMA_Enable(1);
    board->G1_DMA_Config.flush();
    tio->G1_Counting_Mode.setG1_Encoder_Counting_Mode(0);
    tio->G1_Counting_Mode.setG1_Alternate_Synchronization(0);
    tio->G1_Counting_Mode.flush();
    //MSeries.CTR.EnableOutput
    //board->Analog_Trigger_Etc.setGPFO_1_Output_Enable(tMSeries::tAnalog_Trigger_Etc::kGPFO_1_Output_EnableOutput);
    //board->Analog_Trigger_Etc.setGPFO_1_Output_Select(tMSeries::tAnalog_Trigger_Etc::kGPFO_1_Output_SelectG_OUT);
    //board->Analog_Trigger_Etc.flush();
    //MSeries.CTR.StartTriggerRegisters
    tio->G1_MSeries_Counting_Mode.writeG1_MSeries_HW_Arm_Enable(0);
    board->G0_G1_Select.writeG1_DMA_Select(sDMASelect[dmaChannel]);
    tio->G1_Command.writeG1_Arm(1); // arm it
Scott Gillespie
http://www.appliedbrain.com
scott gillespie
applied brain, inc.
(9,307 Views)
Hi Scott-
The "magic" you need is referred to as synchronous counting mode (or Duplicate Count Prevention in NI-DAQmx).  Try setting G1_Encoder_Counting_Mode to 6 (synchronous source mode) and G1_Alternate_Synchronization to 1 (enabled).  I haven't tried this, so there may be other settings necessary that I'm overlooking.  Let me know if you have any problems and I'll dig deeper.
Hopefully this helps-
Tom W
(9,288 Views)
Awesome -- thanks Tom.  I won't be able to try this out until next week.  I'll let you know if it works for me.
thanks much!
--spg
scott gillespie
applied brain, inc.
(9,281 Views)
Tom --
Unfortunately, your suggestion didn't make a difference.  Any other ideas?
-spg
scott gillespie
applied brain, inc.
(9,235 Views)
I'm wondering if my problem might be that I adapted event timing sample code for my application (which is actually doing event counting). Perhaps I missed something in the counter setup, but I just don't see it.
scott gillespie
applied brain, inc.
(9,233 Views)
Accepted by topic author spg
Okay, I have it working now.  In addition to your suggested changes, I had to remove the following line:
It appears that writing something to MSeries_Counting_Mode causes that register to supersede the Counting_Mode register.  Is that right?
So code that now works for  me is listed below.
thanks Tom!
-spg
void eventCounterSetup(tMSeries *board, tTIO *tio, int dmaChannel, bool cumulative, int source) // pfi, or -1 for 20Khz clock
//MSeries.CTR.Gate
// from Tom:
// The "magic" you need is referred to as synchronous counting mode (or Duplicate Count Prevention in NI-DAQmx).
// Try setting G1_Encoder_Counting_Mode to 6 (synchronous source mode) and G1_Alternate_Synchronization to 1 (enabled).
tio->G1_Counting_Mode.setG1_Encoder_Counting_Mode(6); // 0
tio->G1_Counting_Mode.setG1_Alternate_Synchronization(1); // 0
scott gillespie
applied brain, inc.
(9,219 Views)
