Driver Development Kit (DDK)
MHDDK installation on SUSE 11.2
Has anybody successfully installed MHDDK Linux26 driver on SUSE 11.2?
I've seen the instructions in the MHDDK readme file and I seem to be having trouble setting up and configuring the Kernel source so that the driver will compile.  I wondered if anybody could elaborate further on exactly what steps are required?  I am definitely missing something...  I've rebuilt my system about 5 times - it's time to ask for further directions.
Thanks.
Erick
(6,337 Views)
This is quite a pain.
Here is what I had to do:
1.    Configure kernel sources.  When installing Suse 11.2 from DVD, select the
    'Software' option (at the final installation screen) and add Base
    Development, C/C++ Development, and Kernel Development.  This loads a
    matching source tree to the running kernel.  Then Log in into a root
    console (superuser) and configure the compile environment to reflect your
    actual set up.
    cd /usr/src/linux
    make cloneconfig
    make modules_prepare
2.    Add Module.symvers to /usr/src/linux according to this method:
    cp /boot/symvers-2.6.31.5-0.1-desktop.gz /usr/src/linux
    mv symvers-2.6.31.5-0.1-desktop.gz Module.symvers.gz    (rename file in /usr/src/linux)
    gunzip /usr/src/linux/Module.symvers.gz
    If you don't do this you will get missing Module.symvers warning and your
    module will not install.
3.    nirlpk.c has errors. Remove all variables that had errors.  Just that
    simple - remove the variable or the whole line if it's there by itself.
    See attached nirlpk.c and http://forums.ni.com/t5/Driver-Development-Kit-DDK/Problem-with-the-acquireBoard-in-Linux/m-p/842080...
4.    Edit install.sh and unistall.sh : the line with 'source Makefile.in'
    generates a file not found error.  Edit to read: 'source ./Makefile.in'
    See attached files.
I ran ./lsdaq and there is life!
I have not tested uninstall yet.
I am not a Linux wiz.  If you find errors in this please post the 'right way'.  Part of the reason to post this is in case I blow up my system yet again...
Good luck.
- Erick
(6,335 Views)
