Driver Development Kit (DDK)
Multiple channel waveform output using a 6711 board
I am writing a driver for VxWorks RTOS based on the DDK for a NI6711 analog output board.  I cannot find an example for timed waveform output on  more than one channel. I adopted aoex3.cpp (which works fine under VxWorks for one channel) to operate also multiple channels. I set all DACs to timed and wrote to the waveform generation register once for each channel. I tried several settings  for the number of  channels:
    theSTC->AO_Mode_1.writeAO_Multiple_Channels(1);
    theSTC->AO_Output_Control.writeAO_Number_Of_Channels(iNumChans);
None of the settings of  iNumChans results in the correct output  on all selected channels.
The comedi driver uses the settings
   theSTC->AO_Mode_1.writeAO_Multiple_Channels(0);
    theSTC->AO_Output_Control.writeAO_Number_Of_Channels(0); But that does not work either
Any help would be very much appreciated.
Heike
(7,471 Views)
Section 3.6.1.7 of the DAQ-STC RLP manual (http://www.ni.com/pdf/manuals/340934b.pdf) indicates that you are setting the AO_Multiple_Channels and AO_Number_Of_Channels bitfields correctly for mutliple channels.  On which channels are you wanting to generate signals, and what is the behavior you are seeing?
(7,440 Views)
Thanks for your answer Jeremy,
the example attached puts data out on channel 0 and 1. There was a bug in filling the FIFO in he example I attached in my first message. Sorry for that. I attached the corrected one to this  message.  It works fine. I am not sure about the settings of AO_DAC0_Update_Mode and AO_DAC1_Update_Mode. There seems to be no difference when both are set to timed or immediately.
(7,413 Views)
Soory , here is the attached example
(7,411 Views)
