Driver Development Kit (DDK)
PCI-6010 register map / vxWorks driver
I've been trying to perform simple operations on the PCI-6010 in vxWorks.  Some documentation suggests that the E series multifunction boards are similar but the PCI E Series Register-Level Programmer Manual does not seem to work.  I just want to set two analog outputs to constant values (tried following example 1 for the A0 in chapter 4) and to read 4 channels cyclically at low frequencies (10 Hz max) (tried following example 2 for AI in chapter 4).  I can read and set the values in windows but without some idea of how the registers are mapped, I cannot duplicate it in vxWorks.  I do find the two BAR value and use the I/O BAR (BAR 1) but I can't really tell if I'm doing anything.  Someone has to have this interface documented somewhere.  If the 6010 does partly match the E-series, which part and what has to be done to make it work.
(9,266 Views)
Hi Pennels,
have you already downloaded the NI Measurement Hardware DDK (Driver Development Kit) from National instruments?  In the DDK you will find some Examples for M seris boards. aiex2.cpp and aiex3.cpp should provide all you need.
The user has to provide a osiUserCode method in which the bars are set. Here is an example that was written for vxWorks
// osiUserCode.cpp --  Generic Operating System Bus Interface
//                osiUserCode.cpp includes the correct version of osiUserCode.cpp for the OS
//    osiUserCode.cpp holds the two user defined functions
//    needed to port iBus to a target platform.
//    acquireBoard(); -- constructs and initializes the iBus
//    releaseBoard(); -- deletes and cleans up the iBus
//    There are also assorted helper functions which are also
//    platform specific.
    *  osiUserCode.cpp  (framework only)
    *  osiUserCode.cpp holds the two user defined functions
    *  needed to port iBus to a target platform.
    *  acquireBoard(); -- constructs and initializes the iBus
    *  releaseBoard(); -- deletes and cleans up the iBus
    *  There are also assorted helper functions which are also
    *  platform specific.
//    Platform independent headers
    #ifndef  ___osiBus_h___
    #include "osiBus.h"
    #endif
//    System specific headers
    #include <vxWorks.h>
    #include <stdio.h>
    #include <drv/pci/pciConfigLib.h>
    struct pciResource
        unsigned int bar[6];
        unsigned int barsize[6];
        int bus;
        int device;
        int func;
        char irq;
        int errcode;
    typedef struct allUnitsPciRes
        char deviceName[9];
        int vendorId;
        int deviceId;
        int subVendorId;
        int subSystemId;
        int classCode;
        int subClass;
        int revisionId;
        int nBARs;
        int nMmuBARs;
        int nUnits;
        struct pciResource unitPciRes[PCI_MAX_DEV];
    } ALLUNITS_PCIRES;
    /* In this structure you should find all PCI resources of all PCI-6010 boards.
        The code installs only the first one.
        If you have another structure you can use it as well*/
    extern ALLUNITS_PCIRES allPci6010Res;
    /* Return iBus of first matching PCI/PXI card.
    iBus* acquireBoard(const uint32_t devicePCI_ID)
        uint32_t devBAR0,devBAR1;
        //uint32_t BAR0sz,BAR1sz;
        void *mem0,*mem1;
        iBus *bus;
        //Find the PCI BAR memory ranges
        switch (devicePCI_ID)
            /* You have to look up the correct PCI devive Id of the PCI-6010 board using
             * pciDeviceShow(...) from your vxWorks shell*/
                case 0x0000ffff:
                        devBAR0 = allPci6010Res.unitPciRes[0].bar[0];
                        devBAR1 = allPci6010Res.unitPciRes[0].bar[1];
                        break;
                default:
            devBAR0 = (uint32_t)NULL;
            devBAR1 = (uint32_t)NULL;
                        break;
        mem0 =  (void *) devBAR0;
        mem1 =  (void *) devBAR1;
        printf("Base address devBAR0 = %10lx, Base address DAQ_STC = %10lx\n",
                devBAR0, devBAR1);
        //Memory map the BARs to get access to the PCI card's memory
        //create a new iBus which uses the memory mapped addresses
        bus = new iBus(0, 0, mem0, mem1);
        bus->_physBar[0] = (uint32_t)devBAR0;
        bus->_physBar[1] = (uint32_t)devBAR1;
        bus->_physBar[2] = (uint32_t)NULL;
        bus->_physBar[3] = (uint32_t)NULL;
        bus->_physBar[4] = (uint32_t)NULL;
        bus->_physBar[5] = (uint32_t)NULL;
        return bus;
    void  releaseBoard(iBus *&bus)
        //unmap the memory and close whatever system resources
        //were used to create the iBus
        delete bus;
(9,261 Views)
The confusion may come from the board series and which ones are close.  The "preliminary" register mapping for the NI M series does not appear to be the same as the register information in the DAQ-STC Technical Reference manual.  For example, the AI_Command_1 register is shown to be at address 0x08 (word addressing) in the DAQ-STC document but at address 0x110 (I think byte addressing) in the NI M Series Register Map (Preliminary dated Sept 2005).  Since I am using a B series board (6010), should I be using the M series mapping?  (I attempted using the DAQ-STC values and it does not work.)  On top of that, the DAQ-STC document suggests using the window registers to read and write data.   Is that necessary if the B series board is mapped similar to the M series board?
Yes, I already downloaded the NI Measurement Hardware DDK and had already found and mapped the BAR addresses for the board.  I was attempting doing something with the board and that did not appear to work.
(9,231 Views)
sorry I did not understand that this is a B-Series board. According to information found on the NI-Site it should be rather similar to an E-Series, not an M-Series board. I could not find a register map description on the NI pages. But I would be glad abaout any hint where to find one.
(9,228 Views)
Hi All-
Though the PCI-6010 is a B Series board, it is based on M Series hardware.  So, the M Series MHDDK examples and reference material will be more relevant than E Series.  From an AI standpoint, the PCI-6010 is very similar to a PCI-622x M Series device.
Hopefully this helps-
Message Edited by Tom W [DE] on 01-18-2008 08:47 AM
Tom W
(9,221 Views)
