Driver Development Kit (DDK)
PCIe 6509 Full Reset (Register-Level Programming)
We're looking to implement a function using register-level interactions to reset a PCIe 6509 card.  According to the register-level programming manual for the PCIe 6509 card (373665a), the card has a Joint_Reset_Register, which has a Software_Reset bit.
This is the description for that Software_Reset bit:  "Setting this bit to 1 resets the DAQ-STC3 endpoint. One difference between a hardware reset and a software reset is that personality bits are not cleared on a software reset. This bit is a strobe and clears itself."
However, the manual does not specify what exactly a hardware reset does, nor what a software reset does.
If anyone here knows, please describe the full effects of a software reset and a hardware reset, as well as how to perform both (if applicable) using register-level programming.
Additionally, if anyone has the latest documentation available for the relevant STC3 DAQ version used in the PCIe 6509 card, please point me along to it.
Thank you!
Message 1 of 1
(3,672 Views)
