Driver Development Kit (DDK)
PXI 7813R Register Level Programmer Manual available
Is the Register Level Programmer Manual available for the PXI 7813R module?  Does a code example exist using Microsoft Visual C++ 6.0?
Thanks!!!
(7,478 Views)
The RLP manual for the 7813R is identical to that of the 7831R.  The only difference is that you will need to use a different PCI device ID to identify the device, the PXI-7813R device ID is 0x7193.  There are MSVC++ examples at the download link as well.
-Alan A.
(7,463 Views)
