Driver Development Kit (DDK)
Programming Analog Input Registers for MSeries NI-6280 under rtx
I have an example of aiex1.cpp,I kown it write some bit in some register,I want to translate it into RTX.but I found some register is only wirte and I also dont kown what the default bits  in registers is,so use " *(u16*)addr_tmp|= (1 << 7);" is wrong, what can I do about writing some bits in register under RTX? please help me
beilei
(7,394 Views)
This is a double post.  Please see this post for more information.
(7,390 Views)
hello,steven! I found another question when using pxi 6280. the exampels what you give is  collect Finite point,but i want to collect Consecutive points。now I do not kown what register to control how much point I want to collect because of no pdf about pxi6280.i want to kown what regiser to keep collecting  Consecutive points。thanks!
beilei
(7,039 Views)
beilei
(7,038 Views)
