Driver Development Kit (DDK)
Register Level programming of the AT-DIO-32HS
I am working with a piece of software that was written using the AT-DIO-32F card. The original programmer did NOT use the National Instruments driver with that card, but rather used a software library that allowed him to access and manipulate the registers directly on that board. The name of the library is called NTPORT (http://www.zealsoft.com/ntport/index.html).  He did this because he was not able to meet the timing requirements using the NI driver.
We have to replace the AT-DIO-32F card with the AT-DIO-32HS card, and I would like to know if I can continue to do register level programming with the 32HS card.  I have found that I also can not meet my timing requirements using the driver that comes along with the 32HS card.
I checked this web page ([link removed]), and did not find the AT-DIO-32HS listed. Does this mean I can not program its' registers ?
Any feedback would be appreciated !!
Thanks !!
(8,075 Views)
Hi Raminta-
The Measurement Hardware Driver Development Kit (MHDDK) provides examples and register documentation for the 653x devices (which includes the AT-DIO-32HS).  The DIO-32F and DIO-32HS devices are quite similar, so it is possible that your existing code will work.  The resources on the MHDDK page should help you fill in any differences.
Thanks-
Tom W
(8,069 Views)
I visited the web pages you provided, in particular, this page: http://digital.ni.com/express.nsf/bycode/exyv4w?opendocument&lang=en&node=seminar_US#cfiles.    But I did not see anything specifically for the AT-DIO-32HS, or 653x in general (I did see docs for PCI 6533).  Maybe you could just provide me the links to the documentation and examples ?
(8,066 Views)
Hi Raminta-
The PCI-6533 is another name for PCI-DIO-32HS (basically a PCI variant of your ISA card).  The PCI-6533 register documentation should match that of the AT-DIO-32HS and is the most extensive RLP information available for that device.
Thanks-
Message Edited by Tom W [DE] on 07-16-2007 03:38 PM
Tom W
(8,062 Views)
So, manipulating the AT-DIO-32HS's control lines (like ACK1, PCLK1, etc...) USING THE Hardware DDK is more 'efficient'  (with respect to execution time) than using the AT-DIO-32HS's software driver to manipulate those same lines ?
(8,058 Views)
Hi Raminta-
I do not have any data to compare the performance of NI-DAQ and the MHDDK.  It appears that your software is faster (or at least fits your application better) than NI-DAQ, so I suggested those pieces of documentation as a source to help modify (if needed) your application for use with the newer hardware.
Tom W
(8,055 Views)
