Driver Development Kit (DDK)
Sorry, I sent previous messages by mistake, I need help on PCI 6251 register level program
HI, Guys,
Sorry, I sent previous messages by mistakenly pressing the keyboard.
I ahve a PCI 6251 board.  I need to use register level program since I am working on the RT Linux.  My program looks like this:
1) get PCI device
dev = pci_find_device(vender_ID, device_ID, dev);
BAR0=pci_resource_start(dev,0);
BAR_LEN0=pci_resource_len(dev,0);
BAR1=pci_resource_start(dev,1);
BAR_LEN0=pci_resource_len(dev,1);
2) remap the address
mem0=ioremap(BAR0, BAR_LEN0);
mem1=ioremap(BAR1, BAR_LEN1);
3) initialize the MITE Controller
writew( 0xaeae, mem0+0x0340); ( I tried both with and without this line)
writew( (mem1&0xffffff00)|0x80, mem0+0xc0);
4) test DIO Port1
writew(0xffff, mem1+0x028); // set port1 to output
writew(0xff, mem1+0x024); // output high
PROBLEM:  nothing happened when I run this program.
Is there any body can advise me on this problem?  I thank you very much in advance.
BTW, Where can I find the PIN map of the IDC connector on the corner of the board?  Iahve the PIN map of the 68 pins SCSI connector.
Happy NEW YEAR!
(9,636 Views)
In:
'mem1' should be the physical address of bar1 (
BAR1) not the virtual kernel address:
     writew( (BAR1&0xffffff00)|0x80, mem0+0xc0);
Hope that helps,
Diego
(9,625 Views)
HI, DiegoF,
Thank you for your help.  I tried, but it seems still not work.  Do you think there is anything else wrong?
I got the
      Vendor_ID= 0x1093; Device_ID=0x70b8;             by using cat  /proc/bus/pci/devices
I got the
      BAR0 = 0x50002000; BAR1=0x50001000;
after remapping:
      mem0=0xf8922000; mem1=0xf8924000;
BTW,
1)  do I need this line:
      writew(0xaeae, mem0+0x340)?   what's this line for?
2)  Am I right by using:
      writew(0xffff, mem1+0x28); // define DIO port direction
      writew(0xff, mem1+0x24);  //output "0xff" to DIO port
Thank you very much!
(9,619 Views)
>> do I need this line: writew(0xaeae, mem0+0x340)?   what's this line for?
I don't think you need it.
That looks correct.
Try using writel (long) instead of writew (word).  Both the mite and dio mseries registers are 32-bit registers.  The names of the io macros can be misleading, but you can check the linux source include/asm-i386/io.h:
writeb - 8-bits (unsigned char)
writew -16-bits (unsigned short)
writel - 32-bits (unsinged int)
Let me know if it works,
Diego
P.S. some mseries registers are 16-bit, but the DIO registers you are using are 32-bits
(9,596 Views)
Hi, DieoF,
Thank you so much!  the DIO function is working!
My working programe is:
===initial MITE===
writew( 0xaeae, mem0+0x0340); (this is not needed, I deleted it)
writel( (mem1&0xffffff00)|0x80, mem0+0xc0);  (here writel() is needed, writew() doesn't work)
===test DIO===
writew(0xffff, mem1+0x028); // set port1 to output  ( Here both writel() and writew() work for PORT0, writew() may not work with port2, I guess)
writew(0xff, mem1+0x024); // output high ( Here both writel() and writew() work for PORT0, writew() may not work with port2, I guess)
Thank you again.
BTW,  would you mind if tell me how to sample AD channels?  Using Counters?  I am sorry bothering so much.  I am working on my PhD project, I have spent a lot of time to make the card working.  Thank you very much!
Best,
Haihong
(9,592 Views)
Sorry,
should be:
writel( (BAR1 & 0xffffff00 ) | 0x80, mem0+0xc0);
(9,595 Views)
It's no bother, that's what the forums are for...
For MSeries examples I suggest using MHDDK.
Here's some general information on MHDDK:
Measurement Hardware Driver Development Kit Register Level Programming Architecture
Measurement Hardware Driver Development Kit Frequently Asked Questions
How to use a ChipObject
How to Make an iBus
(9,589 Views)
