Driver Development Kit (DDK)
Where can I find tDMAChannel.h
Hellow
Where can I find following files:
tDMAChannel.h, tDMAChannel.cpp
tDMABuffer.h, tDMABuffer.cpp
tLinearDMABuffer.h, tLinearDMABuffer.cpp
tMITE.h, tMITE.ipp, tMITE.cpp.
(7,006 Views)
Download dma.zip located here:
http://ftp.ni.com/evaluation/labview/ekit/other/downloader/dma.zip
In it you will find the following sources:
dma.mak
tDMABuffer.cpp
tDMABuffer.h
tDMAChannel.cpp
tDMAChannel.h
tLinearDMABuffer.h
tMITE.cpp
tMITE.h
tMITE.ipp
The rest of the examples are listed here:
https://lumen.ni.com/nicif/us/evalmhddk/content.xhtml
(6,996 Views)
Hellow, thanks for answer.
One more question:
u32 getCalibrationAreaOffset (const u8 *eepromMemory)
    return (eepromMemory[kCalibrationAreaOffset] << 😎 | eepromMemory[kCalibrationAreaOffset+1];
In function getCalibrationAreaOffset construction (eepromMemory[kCalibrationAreaOffset] << 😎 always equal 0, as since (eepromMemory[   ] have size u8. Is there sense here?
(6,990 Views)
What compiler are you using?
Can you post your definition of u8 here?
(6,986 Views)
Hellow.
I use GNU Compiler Collection (4.3.3) under QNX Momentics IDE.
Function u32 getCalibrationAreaOffset (const u8 *eepromMemory) looks in my code as:
uint32_t getCalibrationAreaOffset (char* eepromMemory)
Objects of type char (and u8, I think) have size 1 byte. But then operation <Object of type char> << 8 always must be equal to 0. Am I wrong? Why?
What real value (offset) will getCalibrationAreaOffset return for PXI-6255?
(6,979 Views)
