Driver Development Kit (DDK) Programmers
X-Series (PXIe-6341) Analog Out Linux
I've been able to get the DIO to work on this card and am trying to get AO to work.  I have the X-Series NIMHDDK and am trying to just get the aoex1 example working.
Has anyone had any success with AO this, I would assume it's in the X-Series packages so it should work?
From the documentation it looks like it is a V out card, so I should be able to scope the AO 0 or AO 1 port, or is it really a current driver and I need a load resistor?
(7,693 Views)
Hi John,
I would expect the analog output examples to work out-of-the-tarball. Are you seeing different behavior?
The X Series devices use DACs to generate voltage; they do not have a current driver. For more information about components and connectivity, see the user manual (page 98 -- https://www.ni.com/docs/en-US/bundle/pcie-pxie-usb-63xx-features/resource/370784k.pdf ).
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,286 Views)
