Driver Development Kit (DDK)
bug fix for NI tCHInChDMAChannel code
ran into a hard-to-find bug in the x-series DDK, you guys might want to correct.
in the routine:
   void tCHInChDMAChannel::_config(nMDBG::tStatus2& status)
near the bottom of the routine is:
      _readIdx  = 0;
      _writeIdx = 0;
there is one more line you need in there:
      _lastwriteIdx = 0;
this doesn't cause a problem for any of the sample programs, since they only use tCHInChDMAChannel once and dispose of it.  however if you start() the channel for a second time without doing a reset (to avoid a buffer re-allocation), the object will incorrectly report the number of bytes available.
--spg
scott gillespie
applied brain, inc.
(6,838 Views)
Hello Scott,
Thanks for letting us know about this.  According to the comments in that file, we expected to be able to stop the dma channel and start it back up.
Steven T.
(6,831 Views)
