Driver Development Kit (DDK)
error : ***no rule to make target all
When I build my project in Qnx  i encounter this error:
*** No rule to make target all
*** No rule to make target clean
 it's an immediate question .please help me
thanks.
Message Edited by zamin on 09-03-2007 04:02 AM
(7,970 Views)
Hi zamin-
Are you using the Makefile supplied with the MHDDK examples?  Which examples are you trying to build?  Are you attempting to build using 'make' from the command line, or from some sort of QNX development environment?  If you are building from the command line, which directory are you in when you run 'make'?
Thanks-
Tom W
(7,953 Views)
