Driver Development Kit (DDK)
exe using ddk
Hello everybody,
I am new to this forum. At present I've started to use the microsoft ddk. Can anybody suggest me how can I build exe using ddk.
I am trying with the function "GdiGetSpoolFileHandle" but it gives me error:
"Linking...
example.obj : error LNK2001: unresolved external symbol "void * __stdcall GdiGetSpoolFileHandle(unsigned short *,struct _devicemodeW *,unsigned short *)" (?GdiGetSpoolFileHandle@@YGPAXPAGPAU_devicemodeW@@0@Z)
Debug/example.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe."
Can anybody help me out....
Also I dont know how can I integrate ddk with my VC++ .net 2006.....
Thanks to all or you in advanced.
chris.
(8,418 Views)
The ddk that this forum is for is a ddk for boards manufactured by National Instruments. You need to find a microsoft forum.
(8,408 Views)
Hi Chris
i dont know much about your error, but i know a method which has worked for me:
first you should have a main.c file. which has to have a function like this:
#include <windows.h>
#include <basetyps.h>
#include <windowsx.h>
#include <initguid.h>
#include <dbt.h>
// todo : some headers
int WINAPI
WinMain (
    HINSTANCE hInstance,
    HINSTANCE hPrevInstance,
    LPSTR     lpszCmdLine,
    int       nCmdShow
//todo
then you should have two files to build the project:
1. "makefile"
# DO NOT EDIT THIS FILE!!!  Edit .\sources. if you want to add a new source
# file to this component.  This file merely indirects to the real make file
# that is shared by all the driver components of the Windows NT DDK
!INCLUDE $(NTMAKEENV)\makefile.def
2. "sources"
TARGETNAME=TODO
TARGETTYPE=PROGRAM
USE_MSVCRT=1
UMTYPE=windows
UMENTRY=winmain
UMBASE=0x1000000
_NT_TARGET_VERSION = 0x0501
TARGETLIBS=\
        $(SDK_LIB_PATH)\kernel32.lib    \
        $(SDK_LIB_PATH)\user32.lib      \
        $(SDK_LIB_PATH)\gdi32.lib       \
        $(SDK_LIB_PATH)\comctl32.lib    \
        $(SDK_LIB_PATH)\cfgmgr32.lib    \
        $(SDK_LIB_PATH)\setupapi.lib
#INCLUDES=C:\WinDDK\6000\inc;..\inc;..\..\inc
SOURCES=main.c
Then you can use "make" or "build" commands to build the project
I think it should work
Regards
Erfan Azarkhish
(8,393 Views)
