Driver Development Kit (DDK)
self calibration of NI PCI-6351 (X series) using the DDK
I am adapting an advanced electrochemical software running on FreeBSD which where written for the NI PCI-6251 (M-Series) for a new customer to the NI PCIe-6351 (X-Series).
The new board is installed and the X-Series DDK examples work as expected. In said EC software I got AI, AO (both with and without DMA) as well as DIO and PFI already working without major problems.
Now I am stuck in finding even the command for doing internal signal routing which would be necessary for porting the self calibration routines, which I wrote in 2009 for the PCI-6251, see here: https://forums.ni.com/t5/Driver-Development-Kit-DDK/self-calibration-of-NI-PCI-6251-M-series-using-t...
I attached to this message my working calibration sub-routines for said M series board.
Questions:
1) How would I set the internal routing?
2) What are the selectors for the positive and negative internal sources?
On the M series board I had:
typedef enum
   noCalsrc=-1,
   scxi0    =  0,
   scxi1    =  1,
   calRef   =  2,
   calSrc05 =  3,
   calSrc2  =  4,
   calSrc10 =  5,
   gndAI    =  6,
   selAO    =  7,
   // derived selectors
   calSrc01 =  8,    // => calSrc05, PWMlo = 3, PWMhi = 2
   calSrc02 =  9,    // => calSrc05, PWMlo = 7, PWMhi = 3
   calSrc1  = 10,    // => calSrc2,  PWMlo = 9, PWMhi = 3
   calSrc5  = 11     // => calSrc10, PWMlo = 9, PWMhi = 3
} pos_src;
enum
   noCalSrcNeg = -1,
   scxiNeg0    =  0,
   scxiNeg1    =  1,
   Tsensor     =  2, // according to a measurement series T in °C = 100*Ut - 50
   senseAI     =  3,
   sense2AI    =  4,
   gndAONeg    =  5,
   gndAINeg    =  6,
   calSrc10Neg =  7
} neg_src;
How do I set a  PWM source?
4) Does the eepromHelper method getSelfCalVoltRef() give the actual value of the internal reference voltage?
I am searching already for several hours in the X Series DDK and its relevant documentation and I could not find anything which is even remotely with similar to the M Series respect to internal signal routing.Many thanks in advance for any help.
Best regards
Rolf
Message 1 of 1
(4,626 Views)
