Driver Development Kit (DDK)
usb9211
I would like to write a driver for USB9211 using libusb on linux 2.4 kernel on x86. I cannot use the ni drivers because of architectural limitations. Is it possible to get the lower-level USB command/response protocols for this device for me to write my own driver? Any other solution?
Anurag
(9,001 Views)
Hi Anurag-
There is currently no support for USB-9162 -based devices (including your USB-9211A) in the NI MHDDK and no documentation to aid in the development of custom drivers for that device.  Instead, NI provides support for Linux users with NI-DAQmx Base.  Can you please elaborate on why this driver solution will not work for you?  The biggest limitation I see is the fact that you're using a 2.4 kernel; I would encourage you to upgrade to a 2.6-based system and use a released version of NI-DAQmx Base.
As a bit more information, NI-DAQmx Base 2.1 provides support for the USB-9211 (C Series NI 9211 and USB-9161 carrier).  A forthcoming release (Q1 2008) of NI-DAQmx Base will provide support for the USB-9211A (C Series 9211 and USB-9162).  More information about the hardware differences can be found here.  Both releases of NI-DAQmx Base do/will provide full driver support with LabVIEW and ANSI C APIs for x86 Linux.
Hopefully this helps-
Tom W
(9,000 Views)
Is there anything new about this?
I cannot get the NI-DAQmx Base to work on Linux. The readDigPort example in nidaqmxbase/examples/dio always returns weird values (0xBF89EE18, 0xBFC7B9E8, 0xBFC15188, 0xBFA67FD8, 0xBF888DF8, ...). They do this even if the device is not connected to the PC ...
But even if it worked, I would not want to use it, because my program should be as independent and light-weight as possible, and it doesn't make any sense to use a library that together with its dependencies is more than 60M (!) big, when the same thing would be doable in a few KBs/lines of code using libusb, if only the protocol specs were made available.
(8,443 Views)
Sorry, this somehow ended up in the wrong thread.
Should have been here instead.
(8,438 Views)
