DutLUG - Dutch LabVIEW Usergroup
Meeting 14-09-2023
Dear DutLUG community,
I hereby announce the presentations for our next DutLUG meeting in September.
Please note that alle presentations will be in person, we will not be recording or live streaming and all presentations will be in English.
Stay healthy and see you all soon! 😊
1. Kitty van der Heyden - Zigbee and MQTT with LabVIEW
I successfully developed a home automation system using Zigbee and MQTT with LabVIEW. The system enables control of various devices and sensors, providing real-time data on temperature and window status. While facing challenges with sensor connectivity and temperature accuracy, I recommended solutions for improvement.
2. John van Schaijk - CNC plasma cutter (DXF to GCode)
This presentation is demonstrating the LabView implementation of converting Autocad DXF file to CNC GCode.
This GCode is used to control a CNC plasma cutter to cut out the desired 2D part from a metal sheet.
The DXF vector format is analyzed and modified to get the correct GCode output.
(2,189 Views)
Hello everyone!
You can download John van Schaijk's presentation on the CNC plasma cutter here!
Thank you!
(1,949 Views)
