DutLUG - Dutch LabVIEW Usergroup
Meeting 17-5-2018
Onderwerpen voor 17 mei:
  • Joris Robijn: Error flow - How to handle errors
  • Danielle Jobe: Interfaces: API Design and .NET LabVIEW Integration
De presentatie slides kunnen na de meeting toegevoegd worden aan deze topic.
Ook zal tijdens de pauze de eerste Coding Challenge worden gehouden! Kijk snel op:
https://forums.ni.com/t5/DutLUG/Battleships-DutLUG-Coding-Competition/gpm-p/3758752
(8,228 Views)
Hello fellow LabVIEW enthusiasts!
Today is the last day you can summit your algorithm, so if you haven't done already, please send your entry to pascal@vi-tech.nl as a zip file, and include your name in the message somewhere.
I will see you this Thursday! Cheers! Smiley Happy
(8,168 Views)
Here is the Interfaces presentation & code. There is a readme that explains how to set it up on your machine to run it.
Tot Augustus!
(8,120 Views)
En hierbij ook mijn presentatie.
Joris Robijn
(8,074 Views)
In the very exceptional case where you want to ignore an error on purpose (without disabling the automatic error handling), you could use the "Error Eater.vi". It looks nice and at least you have a way to find all the places/instance where you broke the rules on wiring the error wire. I don't recommend using this vi often but in response to the presentation of last thursday I wanted to share this with the community.
(8,044 Views)
Love it!
(8,030 Views)
