Dynamic Signal Acquisition
AutoCorrelation/CrossCorrelation
i have some Ni-DAQ-Card and LabView 7.0. i'm working with 2 signlas: X and Y. What i need is:
H(jw)= AutoCorrelation(X) / CrossCorrelation(X and Y)
What is the easyest way to do this?
Problem: AutoCorrelation-Icon have 1 output, and CrossCorrelation have 2 outputs (magnitude and phase) and i dont know how to divide that.
Thanx really
vedran
(7,502 Views)
Hi, vedran
This is what I would do if I were you.
1) convert CrossCorrelation from magnitude and phase to a complex number, and then convert the complex number to real and imaginary parts.(Both functions are available in the Numberic->Complex Palettes)
2) Now let's assume the cross Correlation is C+iD, and AutoCorrelation is A, then
A/(C+iD)=A*(C-iD)/(C+iD)*(C-iD)=A*(C-iD)/(C^2+D^2).
Hope this helps.
Ian Ren
Roush Anatrol.
(7,502 Views)
You can actually do complex divide directly in LabView.
Ian Ren
(7,502 Views)
could u explain it please
(7,502 Views)
Hi, vedran
Attached is a simple example on how to work on the complex number. I cannot find the auto/cross correlation functions in LabView, so I used auto power and cross power instead.
Regards
Ian
(7,502 Views)
Hi, vedran
Both AutoCorrelation and CrossCorrelation should be real (in time domain), I think.
Are you actually trying to calculate the transfer function? then you may be using autopower and crosspower spectrum.
Ian
(7,502 Views)
