Dynamic Signal Acquisition
Can I combine the HP Vee with the Labview?
I already use the HP Vee program to display the measuring data. Now I want to install a control of about 8 analog outputs. Should I use HP Vee for writing this control programm or should I use Labview?
Does it work properly to use both programs, HP Vee for Display of data and Labview for control?
(6,591 Views)
Hi Dominik,
What's the deal brother? Is your life to boring that you would even concider something like this? :<))
Seriously now:
If you go this route, you can't expect to get support for any problems you may encounter. It woulod be just to easy for both NI and HP to just point the finger at the other.
Even though I love LV and push it whenever I can, I would suggest you settle on one or the other.
Ben
(6,591 Views)
