Dynamic Signal Acquisition
Can I connect an earphone or headphone to Analog Output directly?
Hi everyone.
My DAQ board is PCI-4461.
I want to know if I can connect an earphone to AO directly?
According to the spec documents, the minimum working load is 600ohm at Voltage output.
The impedance of the earphone is generally below 600ohm.
The impedance might not be related to the minimum working load.
Anyone who can explain it clearly?
Thanks.
James CHOI
(7,341 Views)
Hi James,
Like you said, the small resistance of your earphones is less than the minimum working load for the analog output of the PCI-4461. Instead of operating out of the minimum working load specification, and trying to draw more current than the analog output can provide, I recommend setting up a voltage divider by adding a resistor in series between your earphones/headphones and the analog output. This would allow you to remain within the tested specifications and still accomplish your task.
Jordan D
Applications Engineering
(7,308 Views)
James,
The 600 ohm load specification guarantees that the output performance will meet specifications. However, it will not harm the 4461 to connect low-impedance loads such as headphones directly to the outputs.
Three things will happen when you connect a low-impedance load to the output:
1) The signal level will be reduced because there's already a 22 ohm output impedance between the output terminals. The 22 ohm impedance and your headphone load will form a voltage divider that will reduce the voltage at the headphones.
2) The 4461 output stage is current-limited to about 25 mA, which will cause clipping if your voltage is at least moderate. If your headphones are, say, 40 ohms, you'll only be able to deliver 1 V into them before the waveform clips. Of course, the actual impedance of your headphones will be a complex function of frequency, so it's hard to say exactly how much voltage you can really put into them, but you won't get more than about 25 mA of current.
3) The distortion will increase even before you go into clipping (though it's likely you wouldn't hear it unless you have golden ears and magic headphones).
If you can live with those impairments, then you should have no problem driving phones directly with the 4461.
Good luck,
Ed L.
(7,244 Views)
