Dynamic Signal Acquisition
Can I synch a 4552 (master) and a 6120 (slave)?
The signal names and possible routngs suggest that I can synch a 4552 (master) and a 6120 (slave) over RTSI. It probably means using DAQmx with traditional DAQ, but I believe that this is also possible.
Am I asking the impossible?
Doug
(7,145 Views)
I didn't make it clear that I'm talking about Analog In only. I realize that there will be a several sample deterministic delay between the 4552 and the 6120. I can adjust the data to compensate if that becomes a problem.
(7,147 Views)
Doug,
You can use Traditional DAQ with the 4451 and DAQmx with the 6120 at the same time. Take a look at the example at this link which synchronizes two 445x boards with a common trigger and sample clock.
Synchronizing Two DSA 445X Boards Via the RTSI Bus
All you have to do is take out the slave portion of the code and replace it with DAQmx code where the DAQmx Timing VI has the corresponding RTSI line as its sample clock source, and likewise for the DAQmx Trigger VI. Here is an example that synchronizes an E-series (DAQmx) with an Analog Output board in Traditional.
Synchronize E Series AI with NI 67xx Devices
Jessica Kinnevan
Applications Engineering
(7,124 Views)
Jessica,
     That sounds like it will solve my problem.  I'm familiar with the multiple DSA card code already, but not with the 6120 or DAQmx. I guess it's time to learn
Thanks very much
Doug Hanna
(7,122 Views)
