Dynamic Signal Acquisition
Can i use OROS Data Aqu. Card in labview
HI
is that possible to use OROS Card in labview for FFT?
siva
(9,275 Views)
Hi Siva,
Yes you can use the OROS card in LabVIEW but because it is a non-NI card, our drivers wont work with it.  If you can reference your own driver, by calling its dll's it will work.
We do not support the use on non-NI products.
Regards
Seamus
(9,247 Views)
National Instruments provides many vibration input cards, from our USB-9233, to USB SCXI with SCXI 1531, to PCI and PXI vibration input boards.  With DAQmx, you get ease of use, support, and excellent measurements.  Give NI a try.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(9,244 Views)
Hi Siva,
Did you manage to make it work (Oros card with Labview) ?
If yes, could you help me because I have the same issue.
Thanks for your help,
Batoon69
(9,194 Views)
I'm using Labview to conduct a modal analysis (Impact Test). I have a OROS Data Acquisition card but it does not work. Please help me with the procedure.
Thank you.
(7,096 Views)
