Dynamic Signal Acquisition
Challenging problem of mimicing hardware screen button choices.
I have an old HP 8757D Scalar Network Analyzer. Since some of the buttons no longer work, I want to use Labview to control all the buttons on the hardware. I can do that and just send the command with the computer. On the main screen of the analyzer, there are eight different buttons. I cannot query to get the buttons (what the choices are), so if I press lets say the calibration button (not one of the onscreen buttons), I need to display in eight different text boxes the eight different choices. Then if I press one of the eight different choices, sometimes eight or less new choices come up on the screen, and then I will need to display those. I do not know what is the best way going about this. If I
try case by case by case, it will not only be tedious but the eight text boxes will have multiple sources and Labview has problems with that. If I try cases in cases, which seems better, I still have the problem of what happens after pressing two buttons - the buttons texts that appear depend on the buttons that have already been pressed (and the order in which they have been pressed). Does anyone have any strategies?
(6,163 Views)
There are several approaches you could take to solve this problem. It might be most fun to use custom Run-Time menus to allow the user to choose what command to execute. Run-time menus allow you to save space, and the user could choose one command that would yield a choice of several other commands, which could cascade to as many layers as you like. You could then use a constant string array that correlate with the different menu choices.
I have attached a very simple VI with a custom run-time menu. The user can select any command and get a unique tag value, which you could then use to select the command you will send to your network analyzer.
(6,163 Views)
