Dynamic Signal Acquisition
Check IEPE sensor connectivity and IEPE status (PCI 4472)
After some discussions with NI support engineers, it appears it is not possible to "poll" the status of IEPE of PCI 447X dervices. One has to either re-set IEPE or keep a track of the IEPE status with his software.
Ian
Message 11 of 12
(4,028 Views)
Hello Ima,
I'm using an IEPE piezo impulse hammer that I'm trying to trigger off of for a modal analysis test.  In my VI I do a pre-measurement to get the DC value of the signal on my 4472, then I add to that value a little (0.002 V) and use that as my trigger level  This way when I tap the hammer it will trigger.  Sometimes this trigger value is over 10V, and the VI errors out because I set a trigger threshold higher than the allowed 10V.  If the 4472 can indeed take a higher voltage during the measurement, how do I get around this?
I usually do 25 or more taps in a measurement, so the 'ocassional' error happens frequently enough in practice to mess up my tests.
Thanks!
Message 12 of 12
(2,998 Views)
