Dynamic Signal Acquisition
Circumvent 9233 IEPE
The technical data sheet for the 401A04 contains the following voltage ranges:
+/-5V input range for correct operation
+/-10V overvoltage (no correct operation, but the device should not be damaged)
The device can be damaged by static discharge, so that could be a possible explanation why some of you damaged their device although the applied input voltage was within the allowed +/-5V range.
Message 21 of 21
(4,216 Views)
