Dynamic Signal Acquisition
Cont Gen voltage Wfm-int clk variable rate + Led off when square wave exceeds 2,5 volt
Hi, example Cont Gen voltage Wfm-int clk variable rate I would like the LED lights up when when the square wave exceeds 2.5 volts. I have a USB 6218. how can I do? Thanks for your help
(6,576 Views)
Hi Giakko,
I saw that you discussed here the same problem on the Italian Forum, so i post the linked documents to let other users to benefict of the support:
Can I Perform Retriggerable Analog Input or Output with an Analog Trigger?
Retriggerable Analog Output with Analog Trigger
Best Regards
Matteo
(6,567 Views)
