Dynamic Signal Acquisition
Discrete signal to a continuous signal
Hi to all,
I'm having this problem with the signal processing, and I hope you could help me...
I have a discrete signal, that is a capturated  with a PIC controller. Now I need that this signal become a continuous signal, so I can use a lot of other VI that I can't use when I have points.
How can I transform the discrete signal in a continuous one?
Thanks in advance,
Ricardo.
(7,615 Views)
I don't know what you mean exactly. A solution to yopur problem might be just to build an array with your points. To do that you can use the LabVIEW function called build array.
Hope this help.
ClémentG
(7,594 Views)
