Dynamic Signal Acquisition
ECG Signal Display and Recording
Does anyone knows how to do real-time ECG recorder with three channel display using Labview? I want to store data with header and ASCII and simulteneously display three channel ECG waveforms. Also same display panel can be used for reading stored data.
(6,955 Views)
I'm not very familiar with Biomedical measurements, nevertheless, acquiring, displaying and saving data to files are very easy tasks using LabVIEW.
I attach an example that generates 2 sine waves of frequencies 10 and 50 Hz, display these 2 waves in a graph and save data to a file (called C:\temp\data.xls)
As you'll notice, you can open this file in MS Excel since I've been using a tab delimited ASCII format.
It should be very easy to modify this example to adapt it to your data acquisition application.
In order ro re-use the same front-end to display previously acquired data, some modifications will be needed - Basically, you will need to open the file, read it (entirely or by chunks) and send the info to a graph.
I hope this will help you
getting started !
Sincerely
Gerald
(6,955 Views)
